Transcoding from 127.0.0.1
Theloozzz
Hello
Is it possible to transcode streams on my pc in version 1.6.2.3. I want to test if I can stream video via internet on a stream of 512 in mpeg2 or mpeg4. If i choose for a external player, WMP or VLC both doesn't work. There is no streaming video via port 3335.
Why should i change die muxer type?
Is this because of the beta version?
No I can't follow you. Who told you to change the muxer type. What do you try to do? What do you actually do?
