2 or more channles at same time
toblerone
hello, i have a single input dvb-s card
question: can i see/record more channels at the same time? obviously in the same sat/band/polarization or as well same frequency
i tried recording a channel with the recording service and look another with DVBViewer (same pc, latest rc1 client) without success
and another test using 2 dvbclient (rc1) on 2 different pc
thanks for any answer
With one card you can receive all not encrypted channels on one frequency.
thanks for the reply
two DVBViewer client on 2 different pc cannot connect (with the recording service) to two different fta channells with the same frequency? i tested just now without success (the channel at change is mirrored to the second client)
does it works only one with recording service and one with DVBViewer?
thanks
