change icon color when recording
danielkoch
i often use the DVBViewer for listening to radio. and i often record things in radiomode. but then the statusbar blinks (disappears because the OSD recording point appears)...
is it possible to change the color of DVBViewer logo into red when recording instead of OSD?
In my viewer the recorder button is gray if i record. In your viewer not?
really? -no, my DVBViewer logo is orange all the time....
did you write any new lines into the setup.ini? by the way: how can i integrate this mediaplayer classic like menu into the DVBViewer? i searched for it but i can`t find it in the forum anymore....
thx
not the logo , the record button in the icon bar !!!
now i understand ;o) yes, the icon in the iconbar i gray, too! but i meant, that the DVBViewer logo should change into red when recording.
Guest Oliver
The toolbar is only available in the full version of the DVBViewer (2.1).
Bye
@Oliver: I own the fullversionof DVBViewer (R3).
I set the SaveCPUPower=1 entry under [Renderer], but nothing works...
o:)
DVBViewer (R3).
which version? Please post your setup.ini
Steffen
DVBViewer V2.0 R3
[General]
OnTop=0
HideMenu=0
Statusbar=1
Toolbar=1
LastSender=141|sunshine live
NoTitlebar=0
XPIcons=3
Cursor=1
CTimer=2
SSaver=1
Winlirc=0
Language=Deutsch
Plugins=\Plugins
Aspect=0
CaptureDir=\Capture
Renderer=3
TaskSysTray=1
Retune=0
NoOverlay=0
IgnoreErrors=0
SplitSize=640
Split=1
Timezone=2
TTLang=8
MiniEPG=0
WinDVBStyle=1
EPGUpdate=0
Filterdump=1
NoEPG=0
Realmpeg=1
ChannelSwitch=1
XPLook=1
Remember=0
Volume=0,400798874746986
Font=Courier New
ZapDelay=1
ZapTimer=1000
Timeshift=
Output=1
Fastswitch=1
EPGPopup=1
EPGPopupDelay=4
Priority=4
RememberPos=1
PersistentEPG=1
SemiTransparent=1
DispRecBtn=1
InfoFile=1
SSaverBF=0
Radiomode=1
AvoidOnTop=1
SmartBuffer=0
BufferSize=2
VMR=80
Skin=0
FirstCPU=1
EPGBefore=0
EPGAfter=0
Autotimeshift=0
[Display]
OnTop=1
VertStretch=0
PanScan=0
LeftOffset=0
TopOffset=0
HoriStretch=0
Duration=2
W=441
H=344
X=583
Y=33
LastLeftOffset=782
LastTopOffset=77
LastRightOffset=1007
LastBottomOffset=270
[Controls]
0=27;0;STOP
Wheel=5
1=114;0;
2=65;0;
4=84;0;
3=83;0;
5=70;0;CHECK
6=0;0;POWER
7=75;0;
8=109;0;UP
9=107;0;DOWN
10=83;2;
20=33;0;
21=34;0;
11=49;1;
12=50;1;
13=51;1;
14=52;1;
15=53;1;
16=54;1;
17=55;1;
18=56;1;
19=57;1;
22=80;0;
23=90;0;
24=79;0;
25=77;0;MUTE
26=38;0;RIGHT
27=40;0;LEFT
-1=0;0;
28=67;0;
32=68;0;
29=0;0;
36=220;0;INFO
37=69;0;SFI
35=86;0;TXT
38=48;1;
40=48;0;0
41=49;0;1
42=50;0;2
43=51;0;3
44=52;0;4
45=53;0;5
46=54;0;6
47=55;0;7
48=56;0;8
49=57;0;9
54=191;0;
55=0;0;
56=0;0;
61=0;0;
62=0;0;
57=0;0;
58=0;0;
50=89;0;
34=82;0;
63=8;0;BACK
64=76;0;
72=122;0;A/B
71=112;4;EXT
73=13;0;OK
74=116;0;RED
75=117;0;GREEN
76=118;0;YELLOW
77=119;0;BLUE
84=32;0;
78=0;0;
79=0;0;
65=0;4;
53=0;0;HELP
89=66;2;
[AudioOut]
Device=DirectSound: C-Media Wave Device
[DeDynamic]
UseDeDynamic=1
Amp=100
PreAmp=30
Radio=0
[Colors]
Brightness=750
Contrast=10000
Hue=0
Saturation=10000
Sharpness=0
Gamma=1
UtilColor=0
[Teletext]
Font=Courier New
TTLang=8
Rendersize=0
RenderSizeX=800
RenderSizeY=600
Color0=0
Color1=255
Color2=65280
Color3=65535
Color4=16711680
Color5=16711935
Color6=16776960
Color7=16777215
Fullscreen=0
Bold=0
[EPG]
Filter=0
ActualFilter=2
[Marfi.AX]
Videocodec=InterVideo Video Decoder
Audiocodec=InterVideo Audio Decoder
[Renderer]
SaveCPUPower=1
LastFile=C:\Programme\DVBViewer\Capture\06-13 10-59-13_VIVA_Neu bei VIVA.mpg
LastPos=0,0099973
[info]
Version=DVBViewer V2.0 R3
[subtitles]
Font=Arial Black|$FFFFFF|18|238|
Shadow=1
Outline=1
[frmFavourites]
X=346
Y=229
W=448
H=334
[frmCreateFolder]
X=458
Y=304
[frmSkinRadio]
X=421
Y=195
[frmSkin]
X=421
Y=195
[frmEPG]
X=149
Y=276
W=604
H=470
[frmTimeshift]
X=304
Y=223
[frmRecWin]
X=395
Y=173
[frmPlaylist]
X=487
Y=149
W=295
H=545
[frmPreview]
X=118
Y=446
W=411
H=300
[frmOpenURL]
X=484
Y=378
[frmChannellist]
X=54
Y=73
W=295
H=621
[frmAbout]
X=441
Y=218
[frmZoom]
X=307
Y=356
[frmColors]
X=208
Y=117
[frmRecorder]
X=232
Y=224
W=646
H=468
[frmTeletext]
X=349
Y=67
W=499
H=522
[frmSearch]
X=393
Y=366
[frmSavePages]
X=404
Y=382
[frmSearchEPG]
X=659
Y=206
[frmOptions]
X=504
Y=99
[urlHistory]
Count=0
Please make an update to 2.1 Our support is for the newest version and not for this old one. You can install the new version in an own directory if you wish. (e.g. in C:\Program files\DVBViewer2 )
Between your and the newest version are nearly 20 revision !
Steffen
Guest Oliver
No, that was between the 1.99 and the 2.0, but there have been serious changes and advancements in the release 2.1.
Bye
thanks! you were right! now it works!
i thougt DVBViewer v2.0 R3 would be the last "public" release and v2.1 only for beta testers.. ->i was wrong ;o)
nevertheless maybe christian can change the DVBViewer icon while recording...
thx
Guest hackbart
well i would not change the icon, but i suppose i will perform the skin routines to keep you informed while recording. There are a lot of plans i have with further releases and so far be for sure that the DVBViewer will become much more a htpc replacement.. o:)
Christian
I'd like that too
A longer time ago I requested something like this for the skinengine along with other skin related issues in the german forum...
"Gerade im Radiomodus fänd ich es sinnvoll, wenn der Aufnahmebutton während einer Aufnahme einen anderen Status als 'normal' hätte. Denn es ist fast unmöglich festzustellen, ob der DVBViewer gerade aufnimmt oder nicht.
Ich denke der 'pressed' status oder ein neuer 'active'-Status wären dafür geeignet. Der Aufnahmebutton könnte dann während einer Aufnahme besonders rot aussehen..."
Quelle (7.März '04)
