breja Posted September 25, 2010 Posted September 25, 2010 4.3 Beta work OK I upgrade 4.5 -> freezes, IHMO EVR problem Uinstall 4.5 Install fresh 4.2 ->frezes! Upgrade 4.3 beta ->frezes! In 4.3 i use codec PowerDVD9 (Use DVXA my GPU) *frezes: Uploaded with ImageShack.us Dont work killtask, restart (stopped and waiting for DVBViewer) only hard restart PC. OFF USB from DVB card -> freezes windows ;] only hard restart PC I can not normally use the program! Windows 7 32bit ATI HD2600PRO (Last CCC) Prof revolution 7500 USB support.zip Quote
Tjod Posted September 25, 2010 Posted September 25, 2010 You have selected CyberLink (PDVD7) as video decoder but this decoder does not exist on your PC anymore. CyberLink Video/SP Decoder (PDVD7): 00602000 (File is missing) It looks like you had installed a lot of decoders but removed them without a proper deinstallation. Quote
breja Posted September 25, 2010 Author Posted September 25, 2010 OK i install PowerDVD 10 and no freezes but problems whith codec its still MPEG/H.264/VC1 Video Decoder: Cyberlink Video/SP Decoder (PDVD10) or Cyberlink Video Decoder (PDVD10) or Cyberlink Video/SP Decoder (PDVD10 UPnP)? "Use Custom Renders" check or no? if check: "VSync by Areo" check or no? "Pre-Format Detection" check or no? I had install again DXVA FIX for ATI (http://home.comcast.net/~exdeus/ati-hd2x00) because yesterday i upgrade drivers ati and FIX was overwritten. Quote
