beachcomber Posted September 25, 2010 Posted September 25, 2010 Hi, The Redruth Terrestrial Transmitter Cornwall UK is now transmitting DVB-T2 High Definition. This is a new format to me and I am wondering if it is visible on DVBViewer Pro without alterations to the DVBViewer Program itself, or do I need to replace the PCI Card when one is available to stream the new standard. I cannot see any HD transmissions on DVBViewer or TransEdit when scanning with my AverMedia PCI Card A16A. The system is transmitted in 256QAM 2/3 32K DVB-T2 Standard. My system: DVBViewer Pro. Cards : AverMedia A16A Terrestrial Card their own Tuner supports MPEG4 H264 but I am not sure about whether it will stream the new format DVD-T2. Technotrend Budget 3200 Sat card. Operating System Windows 7. Processor Core Duo. Can any others in UK get the HD MUX using a Terrestrial Card been able to view these transmissions. Many Thanks in advance, beachcomber123 Quote
Lars_MQ Posted September 25, 2010 Posted September 25, 2010 DVB-T2 Standard. Is a new standard and needs new hardware. Quote
beachcomber Posted September 25, 2010 Author Posted September 25, 2010 Hi Lars, Thanks for quick reply will be on lookout from now for a new PCI card. Trust the BBC to launch a service that is so lightly supported with boxes and PCI cards that not many people can watch it. Will launch BBC1 on Freesat soon so that will be a bit of an sweetener. Thanks a lot, beachcomber. Quote
