MPEG-2 TS to AVI
Nakio
Hello. I wonder if anyone can help me, because I have a file with the following characteristics:
Format : MPEG-TS
File size : 1.99 GiB
Duration : 22mn 6s
Overall bit rate : 12.9 Mbps
Video
Menu ID : 59201 (0xE741)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Duration : 22mn 6s
Bit rate mode : Variable
Bit rate : 12.2 Mbps
Maximum bit rate : 24.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.235
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Duration : 23mn 59s
Video delay : -320ms
This was recorded with DVBViewer from DTV Turner. And I need to pass it to AVI format, for use with software that only recognizes this format.
I try with Nero Vision, but it do not recognize the audio. I am currently working with the Media Coder, pass to Raw separate audio and video and then enclosing in Nero Vision.
I would like to find some software which can convert this file to AVI in one step.
Of course, thank you very much for your help.
