steven627 Posted September 27, 2010 Posted September 27, 2010 Can anyone shed any light as to why in the date separator in the info txt file, optionally created with each recording, is using a '.' instead of a '/' under recording services 1.6.2.3. I've already mentioned this in a different thread but don't seem to be getting anywhere. Has anyone else experienced the same problem? You may not have even noticed it because under normal usage DVBViewer translates it back to '/', however if you need to reload the recording directly into DVBViewer then it does not translate and thus comes out as 30/12/1899. And before anyone says I need to change the setting in 'Regional and Language options' under the SYSTEM account I've already tried this to no avail, i.e. it already was '/'.
