dvbrewer Posted September 30, 2010 Posted September 30, 2010 When I try to scan a transponder/transponders, the only way it seems to pick up new channels is if I unselect everything except FTA/active, but then it also just adds duplicates of all the channels that already exist. Is there no way to just pick up new channels without duplicating everything? Quote
Tjod Posted September 30, 2010 Posted September 30, 2010 I would recommend to use TransEdit. http://www.DVBViewer.com/griga/TransEdit%20E/Content.html There it is possible to selected which channel you like to add. http://www.DVBViewer.com/griga/TransEdit%20E/ScannerWindow.html#ChannelList Quote
dvbrewer Posted September 30, 2010 Author Posted September 30, 2010 Thanks Tjod, I take it that implies it is not possible to add new channels without adding duplicates in DVBViewer's built in scanner? Quote
Tjod Posted September 30, 2010 Posted September 30, 2010 If you selected the old root as target root the channel scan should add all channels which are nor already in the root and update already present channels. But if you like to selected which channels you like to add. You need TransEdit Quote
dvbrewer Posted October 1, 2010 Author Posted October 1, 2010 (edited) If you selected the old root as target root the channel scan should add all channels which are nor already in the root and update already present channels. Yes I do that, same root, if I select update only, new channels are not added, if I don't select it they are added along with duplicates of the existing channels. I did try transedit (new version out today) and I succeeded that way, although you need to be careful to choose the same root. Edited October 1, 2010 by dvbrewer Quote
Griga Posted October 1, 2010 Posted October 1, 2010 if I don't select it they are added along with duplicates of the existing channels. Doesn't happen here. Two possible reasons for your result: - You've scanned without transponder list. - The DiSEqC setting for scanning differs from the DiSEqC setting of the channels, so DVBViewer regards the scan results and channels as different. Quote
dvbrewer Posted October 1, 2010 Author Posted October 1, 2010 Doesn't happen here. Two possible reasons for your result: - The DiSEqC setting for scanning differs from the DiSEqC setting of the channels, so DVBViewer regards the scan results and channels as different. This is it all my channels are set to DiseqC none, but scan seems to default to pos B/opt B, thanks Griga! Quote
