Problem with webserver
I have DVBViewer 4.0 pro and webserver v1.5 installed. The problem is when I use the webserver everything is fine until I select to play a channel. I use WMP plugin but when I click on "Start streaming" the WMP shows up but fails to connect after a few seconds. When I press the paly button is tries to conect for a few seconds and stops again.
What can be wrong?
Streaming through DVBViewer itself is ok and I can watch it using VLC.
Does is need some kind of setup on VLC? Cause it says VLC is streaming on the webserver.
Thanks in advance
