JordiV Posted October 5, 2010 Posted October 5, 2010 I have problems since I installed DVBViewer Pro 4.5 RC2, when I see a satellite channel gives me error dvb device not found, I have a skystarhd, how that is the problem? thank you very much Quote
Lars_MQ Posted October 5, 2010 Posted October 5, 2010 Please post some more information: http://www.DVBViewer.tv/forum/index.php?showtopic=2210 Quote
JordiV Posted October 5, 2010 Author Posted October 5, 2010 Ok,sorry I have problems since I installed DVBViewer Pro 4.5 RC2, when I see a satellite channel gives me error dvb device not found, I have a skystarhd, how that is the problem? thank you very much support.zip Quote
Tjod Posted October 5, 2010 Posted October 5, 2010 The Recording Service is not set up correctly. Please follow the instructions in the Installation Guide e.g. disable the real hardware in the DVBViewer. http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide Quote
Lars_MQ Posted October 5, 2010 Posted October 5, 2010 read http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide Quote
JordiV Posted October 6, 2010 Author Posted October 6, 2010 as you can uninstall the The Recording Service? thank you very much again Quote
Gioxy Posted October 6, 2010 Posted October 6, 2010 as you can uninstall the The Recording Service? Two steps: 1) unistall Recording Service like every other app from "Control Panel" / "Program and features" ( or "Add or Remove.." ) 2) in DVBViewer Pro go to "Settings" / "Options" / "Hardware" 2a) remove the "Unicast Network Device" you set for Recording Service 2b) set all active DVB device to "normal" ...that's all... Quote
JordiV Posted October 6, 2010 Author Posted October 6, 2010 Two steps: 1) unistall Recording Service like every other app from "Control Panel" / "Program and features" ( or "Add or Remove.." ) 2) in DVBViewer Pro go to "Settings" / "Options" / "Hardware" 2a) remove the "Unicast Network Device" you set for Recording Service 2b) set all active DVB device to "normal" ...that's all... thank you very much Quote
