psykix1 Posted October 5, 2010 Posted October 5, 2010 Is it not possible to have channels sorted in the OSD? I can't find an easy way to do it... Quote
mague Posted October 6, 2010 Posted October 6, 2010 There is a channelist editor in the members area. With this you can sort your channels. Then, with DVBViewer you may sort them further into favorites. Quote
psykix Posted October 6, 2010 Posted October 6, 2010 Thanks for the reply, I'll check it out :-) Quote
SimonP Posted October 8, 2010 Posted October 8, 2010 You don't even need the channel list editor. Just open DVBViewer's channel editor, select 'Edit favourites', then drag the channels you want across to it and sort them. Now when you click on 'Channel' or 'Favourites' you'll see your sorted list. Quote
roboc Posted October 16, 2010 Posted October 16, 2010 This is clear, BUT, is it possible to use the channels with numbers(to use it with my remote control for direct access) sorted as Canal Satellite ? Thanks for your help Quote
SimonP Posted October 20, 2010 Posted October 20, 2010 Have you tried entering the numbers shown at the bottom left of the DVBv screen next to the channel name (when not full-screen)? They may not match your EPG numbers (I use Freesat in the UK and don't have an EPG as such) but that certainly works. Quote
