Channel export import
Flepp
Hello Christian
- A nice feature would be to add import/export channels in csv format.(komma or tab delimited)You only need to define the format or take existing ones as satcodx text files
ex:
http://www.satcodx2.com/_data/0192.txt
The advantage would be that channels can be sorted by criteria in any tabulation program or i take channelist from my nokia box and import it to DVBViewer.
Another simple solution would be to convert the channel.ini file into csv or visversa but i didn't find any tool for doing it.
-check existing entries when importing channels
-Also is it possible to enable teletext in radio mode ?
Regards
Flepp
