nebula2010 Posted November 4, 2010 Author Posted November 4, 2010 Thanks for the info but i didnt find the readme i will fix this Thanks Quote
PeterF Posted November 5, 2010 Posted November 5, 2010 Thanks for the info but i didnt find the readme i will fix this Thanks The readme-file is called "DVBViewer GE\DVBViewer_GE_ReadMe.rtf", and is located in the "DVBViewer_GE_3_0_1.zip"-file. PeterF Quote
rulett Posted December 1, 2010 Posted December 1, 2010 So, if I understand right X3M SPC1400HD PCI-card is currently supported by DVBViewer? Quote
nebula2010 Posted February 14, 2011 Author Posted February 14, 2011 The latest version of DVBViewer does everything perfectly thanks this program is the best DVBViewer yet Thanks Quote
NebulaUK Posted June 20, 2011 Posted June 20, 2011 Hi i have been enjoying using DVBViewer alot although transedit is now broke when i try and scan a frequency it fails to initialize the device and i also notice there is now a new vendor id Vendor.0=27 attemting to change it to its old value of 2 it still wont scan frequency although DVBViewer works fine please help me. Quote
