Seven WMC + DVBViewer Pro 4.5
ricabullah
Hi guys.
First of all thanks to devs for new 4.5.
I loved EVR Custom very much.
So back to the headline:
What is the current and simplest way of using DVBViewer with seven MCE?
Thanks in advance.
Close down MCE, start DVBViewer. :)
Weird, yes it works :bounce:
Does it mean no way else?
Edited by ricabullah
I have found it works equally well that way with XP Media Centre, Vista Media Centre and Win7 Media Centre. If you have DVBViewer why would you need those under-performing Microsoft products?
Trying to setup a handy HTPC -not for myself for sure;
that is the reason.
My HTPC works fine using DVBViewer as the main viewing platform. My wife has no interest in technology can use it without problems.
