rafal82 Posted October 10, 2010 Posted October 10, 2010 (edited) I wanted to add to miniepg signal strength and the bitrate when it is added it is not displayed. What can I do to make it work Edited October 10, 2010 by rafal82 Quote
w8andc Posted October 18, 2010 Posted October 18, 2010 A few days ago I also tried to figer out how to implement bitrate, samplerate and audio modus into the miniepg. This info is shown in the mysisinfo.xml. By using the OSDskinner I searched in this xml file for a logical connection, but can't figer it out. After comparing different OSD-skins it seems: 1) the label controlID is always the same. video bitrate --> controlID = 60 audio samplerate --> controlID = 54 audio modus --> controlID = 55 2) No variable is connected to the labels. By using DVBspy no variable beginning with #bitrate or something equivalent is shown. conclusion: It seems putting a label with ID = 60 is not sufficient to show the bitrate. I miss something or it has to be done in another way? Some info is appreciated from someone. Thanks. 1 Quote
bl4ck Posted December 1, 2010 Posted December 1, 2010 (edited) delete Edited July 19, 2012 by bl4ck Quote
