Mpeg4 Ts to MPG with TSPlayer
Robertooo
Hi
I've got a question. I've recorded (mpeg4 - because I'm Hungarian) ts file with DVBViewer 4.5 pro and I can play it with TSPlayer but the conversion isn't working perfectly when I want to transform the ts file to mpg. TSPlayer makes mpg file but I can't play it because other players can't play the mpg file.
But when I translate mpeg2 ts file to mpg it's working perfectly and I can play it perfectly.
Have somebody got any ideas for this problem?
Thx
..mpg program stream (PS) is not defined for h.264, so even if the format is changed correctly, it doesn't make sense ;)
Thanks.
I see now that the info of mpeg2 ts file is: MPEG2 video; and the info of mpeg4 ts file is: H.264 video.
So this will never be possible with H.264 ts file in the future?
..why do you want h264.mpg when no other program will play it?
