Can I reference NTFS file properties in OSD # ?
groovyclam
I am amending some of the default OSD xml files to learn how to make my own OSD skin.
When DVBViewer is playing back a file it has opened with "Open Video" can I reference the contents of the following NTFS File Info fields of the file DVBViewer is playing in the OSD xml and if so what are their #tag names to be used in the XML ?
Title
Subject
Keywords
Comments
Source
