Channel list editor export & hauppage
toblerone
i'm using the "channel list editor" export funcionality
and i have a question about the "pilot" hauppage's tag needed sometimes with the dvb-s2 channels
i see that is not present a specific related field in the csv exported file
but
comparing 2 different csv files with "pilot" actived and not, i noticed that the colums #22 (satmodulation) change eg from 132 to 4
the same looking at the exported .ini file
the question: is there a relation beetween that 2 values (i'm trying to change they automatically if needed without click 38432009432 times every scan/different channel list) or not?
eg: pilot on '=satmodulation +128' can be it?
regards
Edited by toblerone
Several properties are coded bitwise in the SatModulation value. Starting with Bit 0 (the least significant resp. rightmost one):
Bit 0..1: Modulation (00 = Auto, 01 = QPSK, 10 = 8PSK, 11 = 16QAM)
Bit 2: Modulation system (0 = DVB-S, 1 = DVB-S2)
Bit 3..4: Roll-Off (00 = 0.35, 01 = 0.25, 10 = 0.20, 11 = None)
Bit 5..6: Spectral Inversion (00 = not set, 01 = auto, 10 = normal, 11 = inverted)
Bit 7: Pilot Symbols (0 = off, 1 = on)
You can use the Windows calculator for decimal <--> binary conversion. The decimal value of bit 7 is 27 = 128.
yep, i thinked about 128 for the binaries>dec convertion
thanks for the explain
i have tried to import a sdx file without success
You would need a sdx import plugin. However, the sdx format doesn't cover the DVBViewer requirements anymore. Important parameters are missing. That's why the plugin is no more available in the members area.
Even if you have such a plugin in an old DVBViewer installation - I wouldn't use it anymore.
  • 5 weeks later...
Any suggestion/idea for convert FROM some other "used" format TO the DVBViewer one (.ini or .csv are fine)?
Edited by toblerone
