DVBViewer Pro 4.5: increased EVR stutter
Laserwave
After upgrading to v4.5, I get frequent freezes with EVR. Trying the custom renderer seems to make things worse, although it is random and sometime the problem is not so apparent. I mostly use the Microsoft video decoder which didn't have any problems with the previous DVBV version, and hardware de-interlaces nicely in both MPEG 2/4.
Video card: Asus ENGT240/DI/1GD3, Nvidia 258.96, Intel P35 chipset, Hauppauge HVR-4000 (driver v.2.125.28070.0 included in wintv 2.2, WinTV not installed).
try another audio (AC3Filter) and video (Cyberlink -> activate DXVA) decoder.
4.5 runs perfectly fine on Windows 7 with EVR on "weak" hardeware/gpu" for sd and hd. finally i have "laufschriften" on n-tv withouth stutters for hours.
but every 10th channel switch i don get the station. then i have to switch back and forward to tune. anybody else? wasnt that bad with 4.3 beta
Thanks, I tried that and various other filter combinations but it didn't help.
So, I put back an ATI 4650 card, and problem solved... :|
Clearly it's not a matter of power since the nVidia is more powerful, but probably something to do with their x64 drivers (also had many crashes).
Edited by Laserwave
