Resize limit
CCTVHK
Dear all,
There seems a limit to resize the DVBViewer window in version 4.5, it is even not possible to reach the screen border. Is there any tweak available to get around that limit ?
Thanks.
Dear Lars, hope I am not mistaken. Pls try in a non-full screen mode with version 4.5, and then resize the window by rolling the mouse wheel and see what happen. There is a maximum size limit, not even reaching the border of my screen. I have been using 4.0 version but never have that problem. Many thanks.
did you try to do resize the normal way? otherwise just send it to fullscreen.
I just tested it. I can resize the windows to the borders. What do you mean with "rolling the mouse wheel"? I resize by dragging the borders of the window. Maybe your mouse specific mouse rolling is a problem?
Dear both, there are under Option - Input - Mouse some checkboxes where we can choose the action of the mouse wheel. The options available are resize, zoom, volume up/down, etc. This is quick and convenient way, better than pulling the border. Would be grateful if you can try it in your machine and get back to me. Thank.s
ah ok I see. It sometimes doesn't resize fully. Approx. one cm is left. If I resize it manually by dragging the borders to "nearly full screen" then I can afterwards roll the wheel and make it smaller and bigger again. Maybe that works for you.
Thanks for your time, I hope that feature can come back at one day. It was nice.
