Preview in HD not working anymore !
themaster1
I post here but i guess i could have posted in the bug section.
The issue concern the Preview of one channel in HD, it doesn't work anymore with the v4.5 (worked great with the previous beta version ! )
As a result i have the image that's flashing, totally unwatchable if you ask me and i use two different codec (PDVD10 / CoreAvc) so something has been done wrong in this new version.No matter what the combination i chose (Overlay / VMR7/9) it just don't work for the preview in HD.
Oddly enough, in SD it seems to work just fine.
Also, on another note , i can't swap the sound & channels anymore with the keys 0 or 5, what's up with that ? (this worked great on the previous beta version)
Edited by themaster1
More infos as i'm experimenting:
The problem seems to occur in YV12 color space.
In RGB32 or YUY2 (CoreAvc) it seems ok but the cpu resources go up!This need to be (re) fixed
I use
For Video A: PDVD10 / Overlay
For Video B: CoreAvc 2.0 / VMR9
Xp Sp2
try the vmr9 custom renderer.
No it don't work in YV12 anymore ! The image is flashing every second as if there was a freaking stromboscope in the room. VMR9, Overlay, Custom renderer it don't matter there is something wrong related to the color space, i'm 100% sure of it. It worked fine with the previous beta
