eustonstreet Posted October 14, 2010 Posted October 14, 2010 Hi, I've just gone from DVBViewer 4.2.1 + Recording service to DVBViewer 4.5 + latest Recording Service. Previously, using 4.2.1 I would see both BBC 3 & BBC 4 in the channel list & EPG. Not immediately after a channel scan but sometime later they would appear as if by magic. With DVBViewer 4.5 + recording service they no longer appear. I have tried channel scanning & updating recording service EPG after 7pm when CBEEBIES & CBBC switch over, but still nothing. problem is only for BBC 3 & 4, EPG works fine for other Freesat channels. Sorry if it's a noob 'ish question, previously everything just worked to I had no reason to fiddle with the setup. I have used search but still can't find answer. Thanks for any help Ian Quote
eustonstreet Posted October 14, 2010 Author Posted October 14, 2010 (edited) I found them (BBC THREE & FOUR)using TransEdit with Hide Inactive Channel filter checked. Strange that DVBViewer doesn't find the with 'Only Active Channels' unchecked in channel scan? Whatever, it's sorted. Ian Edited October 14, 2010 by eustonstreet Quote
Griga Posted October 14, 2010 Posted October 14, 2010 I found them (BBC THREE & FOUR)using TransEdit with Hide Inactive Channel filter checked. There is no "Hide Inactive Channels" filter option. You found them with "(Show) Inactive Channels" checked, right? Strange that DVBViewer doesn't find the with 'Only Active Channels' unchecked in channel scan? No problem here to find CBBC and CBeebies (currently inactive) Quote
