Ivan Fung Posted October 15, 2010 Posted October 15, 2010 Hi, The DVBViewer Pro was working fine in previous version 4.2.1 and the various beta downloaded from old members area. However, it shows "No hardware Available" after updated to Ver 4.5.0.0 when I switch the channel (It showed blank screen when I start the DVBViewer initially). The new version seems can detect the TV Tuner, but it shows different model no. of the TV Tuner( In the Setting->Option->Hardware, it shows the detected TV Tuner as "7160 BDA DMB-TH Tuner" but in fact my Device Manager shows it is "NXP TV7138 DMB-TH/PAL Hybrid Device"). Attached please find the support.zip and below please find the other information. Graphics Card : NVIDIA GeForce GT220 Driver : 8.17.11.9732 TV Tunder : NXP TV7138 DMB-TH/PAL Hybrid Device Driver : PEGATRON GROUP 1.0.4.3 PC Model : HP-Pavilion S5188hk Mother board specification : PEGATRON Corporation : IPIEL-LA3 (Eureka3) http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01746799&tmp_track_link=ot_faqs/top_issues/en_hk/c01746799/loc:4&lc=en&dlc=en&cc=hk〈=en&product=3986214 Thanks, Ivan -- support.zip Quote
Ivan Fung Posted October 15, 2010 Author Posted October 15, 2010 One more info, the OS is window 7 Quote
Griga Posted October 15, 2010 Posted October 15, 2010 it shows the detected TV Tuner as "7160 BDA DMB-TH Tuner" but in fact my Device Manager shows it is "NXP TV7138 DMB-TH/PAL Hybrid Device"). The device and tuner filter name may be different. Perform Options -> Hardware -> Detect Devices. Any change? Additionally tick Options -> Hardware -> Use Internal Network Provider Filter. Does it help? Quote
Ivan Fung Posted October 16, 2010 Author Posted October 16, 2010 I tried "Scan Device" button again and tried delete the device and scan again but nothing change. The "Use internal Network Provider Filter" also does not help. Any idea? Quote
Ivan Fung Posted October 21, 2010 Author Posted October 21, 2010 It nothing can be done so far,Can I downgrade to v 4.2.1 ? Quote
Griga Posted October 21, 2010 Posted October 21, 2010 TransEdit doesn't work either? Can I downgrade to v 4.2.1 ? DVBViewer Pro 4.2.1 ist still available in the old members area http://www.DVBViewer.com/members/ (see Older Versions section). You'll need your old credentials to log in. Quote
Ivan Fung Posted October 22, 2010 Author Posted October 22, 2010 The TransEdit ver 3.4.2.0 located in the DVBViewer directory works fine. It can detect the channel and show some preview. Any idea? Quote
Griga Posted October 22, 2010 Posted October 22, 2010 TransEdit has detected the device under the same name as DVBViewer Pro 4.5 (7160 BDA DMB-TH Tuner), so that's not the source of the trouble. In order to narrow it down, do the following: - Start DVBViewer 4.5 via Start -> Programs -> DVBViewer Program Group -> Support -> DVBViewer (Debug Mode). Tune some channel, close DVBViewer and again attach a support.zip (now containing a debug.log). - Tick Settings -> Hardware -> Use Internal Network Provider Filter in TransEdit. Does it still work? - Try TransEdit 3.6 from the new members area (keep a backup of the old version). Does it work with Use Internal Network Provider Filter ticked / unticked? Quote
Ivan Fung Posted October 22, 2010 Author Posted October 22, 2010 Hi Griga, 1. Attached please find the support.zip after running debug mode. 2. For TransEdit 3.4.2 . It works fine after I Checked on and off for the Hardware Setting : Use Internal Network Provider. 3. I can only download the TransEdit 3.5.4 (instead of 3.6) in the new members area. It works fine also for both on and off setting. Please let me know where I can download the TransEdit 3.6 if it is released. thanks, Ivansupport.zip Quote
Griga Posted October 22, 2010 Posted October 22, 2010 I can only download the TransEdit 3.5.4 (instead of 3.6) in the new members area. The only TransEdit version in the new members area (from where you have downloaded DVBViewer 4.5) is TransEdit 3.6! Quote
Lars_MQ Posted October 22, 2010 Posted October 22, 2010 Are you sure you use the correct channel list in the DVBViewer? It seems you try to tune a DVB-S channel with a DVB-t device or something similar. Quote
andy_ko Posted October 23, 2010 Posted October 23, 2010 Hi, I encountered the very same problem today, after upgrading to Pro 4.5 (using a Hauppauge Win-TV-HVR 4400 under Windows 7). The tips given bij Griga didn't help me either. But this is what brought back audio and video to DVBViewer: I uninstalled Recording Services and suddenly al was fine again. Any explanation for this behaviour? Andreas Quote
Tjod Posted October 23, 2010 Posted October 23, 2010 @andy_ko I think you have missed the part with the Unicast device and disabling the real hardware in DVBViewer. http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide Quote
andy_ko Posted October 24, 2010 Posted October 24, 2010 @Tjod, Indeed, I had missed that. Thank you for pointing me to this important detail. Quote
Ivan Fung Posted October 26, 2010 Author Posted October 26, 2010 Hi Griga, After tuning the Channel list by "Scanning Range", it is oK to detect the device and get the signal. Thanks, Ivan Quote
cmjklein Posted August 11, 2017 Posted August 11, 2017 I spent ages trying to get this to work. I solved it as follows Make sure RTSP is enabled on the server. On the client go to hardware and in devices on the right side delete any that are there then select add, then select RTSP network device. Enter the ip address of the server and the ports exactly as the RTSP settings on the server. Close and reopen the client and it worked for me. The only issue I had then was that I got sound but a black screen. I resolved this by going to settings and selecting Video output B. All ok now. Quote
