Actual Size playback
dannii
Is there a way to have video playback at exactly the size it is ?
So that 720p material would use exactly 720 pixels vertically and a PAL standard def would use exactly 576 pixels vertically ?
ITunes playback has an "actual size" option that seems to do this. I think this gives the best picture because there is no upscaling or downscaling involved.
Thanks
(...Obviously...) you have to be in windowed mode, then:
• right click on view area and choose "View / Zoom / 100%"
BTW, you can assign a remote button to that, see:
"setting / Options / Input / Screen control / 100%"
Also you can command DVBViewer to do so with action "30"...
find all actions command in "actions.ini" file in main DVBViewer folder
Anyway, if you have a good Video Card / MPEG2 decoder
IMHO you shouldn't see big quality differences...
:bye:
Hi Gioxy,
Ive been away for a few days...
Don't know how I missed that zoom 100% but I did so thanks.
It may be wishful thinking but any upscaling looks bad to me.
If it's got 720 lines then I want to watch it with 720 lines, 720 comes out at about a 28inch diagonal on my 1080 line 42inch plasma which is the size of my old CRT !
thanks again
