DVBViewer 4.5 don't save LOF and DISEQ settings for the while sate
evgen_ln
Look like DVBViewer 4.5 don't save modified LOF and DISEQ settings for the while satellite node. I had to change the desired settings for each channel separately.
Here it works.
When applying LOF1/LOF2/LOFSW settings, the 22 khz off/on and LOF settings of all channels within the root folder are updated accordingly, and of course these settings are saved in the channels.dat file. However, the UI doesn't remember the originally entered LOF1/LOF2/LOFSW values (because they cannot be reconstructed from the resulting per-channel settings), which may be a bit confusing.
That's the problem that on older versions when you select the satellite node and setting LOF options, and then clicking the "Apply", the settings was applied to all embedded channels. On ver 4.5 this method does not work. I don't known on what version it stopped working because I use this feature seldom. I tried to set LOF to 10750,10750,0(circular LBN) for all Satellite channels but without success. I had to export the satellite node and edit it using Notepad “Replace”, and then import.
