Incorrect characters in EPG
Tyro
After installing v. 4.5 the swedish characters å, ä and ö don´t shows correct if i import data via TVxb grabber. If I take down EPG-data from my provider via satellite all characters shows correct. Is there anything I can do to fix this problem?
Have you tried XEPG ?
works fine for me with ÅÄÖ, i'm using xmlTVswe as the grabber.
