Bug in OSD EPG Mode
bogdan1980
i find an bug, present in all version, if i tap Enter to see osd epg, the hours are shown righ this:
11:... instead of 11:30 for example,
all hours are cut, 1:... , 2:..., etc, instead of 1:10, 2:30, etc..
There was an russian here that post same bug.
Tested with 4.2, 4.3, etv
thats no bug. The time is too long. Which format do you use? You might have to adjust the time fields in the miniepg.xml skinfile.
Lars, do not be mad at me, i do not understand "what format " you need, ask?!
Also, i find out myMiniEPG.xml but i do not know what to modify here:(
I have an 1280x1024 lcd, default skin for DVBViewer, menu style-vista , no skin.
Have you tried other OSD skins? Look in the OSD skin subforum in the German part of the forums, or on the German wiki. You might not understand the language but you'll get the idea quick.
Sorry didn't meant to seem "mad at you" that's not the case. :)
I meant which time format do you use. I guess an AM/PM format which is way too long for the default skin (it's designed for a 24 hour format).
As @uglyned stated, take a look at the OSD Skins available, there are some really nice ones. You don't have to understand german, I think most come with english installation instructions.
Yeah sorry - I meant understand German to work out where they are in the German forums / German wiki. Not the skins themselves.
