monster55 Posted October 21, 2010 Posted October 21, 2010 hello i have a skystar 1 ci and it dosent work in DVBViewer the program just dosent see it thanks support.zip Quote
Lars_MQ Posted October 21, 2010 Posted October 21, 2010 Skystar 1 (the one with the hardware mpeg decoder onboard) is NOT supported and does not work with the DVBViewer. It did never work and it will never work. Afterthought: OK, this is one of the name messups by technisat. If the name is really "Skystar 1 CI" then it is a labled twinhan 1030a (Twinhan Vision DTV). This should work with the DVBViewer. Do you use the most recent (BDA) drivers? Quote
