JordiV Posted October 23, 2010 Posted October 23, 2010 I have a little problem with some HD channels with the channels above the image is fast for example sports channels, the picture is not fine, in the normal HD channels cinema, series, cartoons, documentaries, works perfect, but in non-sports HD channels. What could be the problem? The pc I have is the following; Motherboard-Gigabyte GA-MA785GT-UD3H AMD Athlon processor-TripleCore II X3 435, 2900 MHz (14.5 x 200) Memory-2 GB DDR3-1333 DDR3 SDRAM Graphics card-ATI Radeon HD 4550 Series I used all the codecs cyberlynk10, core, etc ... thank you very much from now support.zip Quote
Jelmo Posted October 25, 2010 Posted October 25, 2010 Without watching the support.zip i think this channels commes with 1920x1080i. So your Graphic card has to deinterlace to 1920x1080p. And sport channels = fast moves. Movies most time slow moves. I think if you put a radeon 5xxx in your system, this problem should be solved Quote
test Posted October 25, 2010 Posted October 25, 2010 Graphics card-ATI Radeon HD 4550 Series this card is not able to do de-interlacing correctly. Minimum card for good de-interlacing is an ATI 4670 or NVIDIA GT220. check http://www.avsforum.com/avs-vb/showthread.php?t=1157287 for testing de-interlacing capabilities of your card(s) maybe also your TV has some "wrong" MotionFlow/MotionPlus/IFC/$whatever settings active ... Quote
