zomperman Posted October 23, 2010 Posted October 23, 2010 (edited) Hi I have a computer with a Dual DVB-S2 card running latest Recording Service and DVBViewer 4.5. DVBViewer is configured to use a Unicast Tuner from the local recording service. And this works. I have a second computer with DVBViewer 4.5 installed that is also configured to connect via Unicast to the recording service of the first computer. Everything works but only if I use one client at a time or tune the same channel on both. If I want to watch 2 different channels on both clients only the first client has the video/audio and on the second I receive only black screen. But no errors reported (like Hardware in Use... etc....). If I watch the same channel then I can watch it on both of them. Is there anything I missed in the configuration? I'm pretty sure that his configuration worked sometime a go but can't remember exactly with which version. I dont use any plugins on client and/oe recording service. I'm watching FTA channels. If I test both tuners locally directly in the DVBViewer client then it works (without recording service). thx for any help. Edited October 23, 2010 by zomperman
zomperman Posted October 29, 2010 Author Posted October 29, 2010 Problem solved. Cable ... grrrrrr....
