krasno Posted October 23, 2010 Posted October 23, 2010 HI Maybe it's not a new thing, but if anyone can use it... I can I found this, to my opinion brilliant software.. or half brilliant I should say:)Forexample it is possible to get out of DVBViewer and jump into Windows explorer, or a browser, and then go back to dvbv, not leaving the sofa. http://thedigitallifestyle.com/cs/TDL/b/stuart/archive/2009/06/01/turn-your-mce-remote-in-to-a-mouse-amp-keyboard.aspx And more here: http://thegreenbutton.com/forums/t/41277.aspx?PageIndex=1 In short terms the remote can be used as a mouse, and also as a keyboard same way you use a cell-phone, that part don't work here, so therefore the half-brilliant statement. Also I have a few problems with the real-keyboard, but I'm working on that... or I should say:I try.. to toggle between mouse, keyboard and suspend mode : use the "*" button The software is 100% free. Quote
krasno Posted January 26, 2011 Author Posted January 26, 2011 New updated version. Now the keyboard mode works in Win7 !! http://thedigitallifestyle.com/cs/tdl/b/stuart/archive/2009/06/01/turn-your-mce-remote-in-to-a-mouse-amp-keyboard.aspx I use the .exe version And it works !! In keyboard mode it is possible to type same way you type sms's on a cell phone. follow installation instructions: http://www.autohotkey.net/~kane2742/RemoteKC%20Readme.rtf Quote
krasno Posted February 20, 2011 Author Posted February 20, 2011 Just tried this. Recommended...! It works well.. but: The only problem here is when using a real keyboard-danish keyboard- It is not the asterics "*" that toggle between modes, but left bracket, which means left bracket does not work at all when typing, not very brilliant when typing in spreadsheets Till now I have not found out how to change that.. Quote
