Network Streaming with 4.5
hollymolly
Sorry I dont get it how to setup up DVBViewer over the network. Any help appreciated!!!
Installation
Computer ABC: Has DVBViewer 4.5 with DVB-C Card running. Everything works fine. TV can be watched on this PC. No NetStream.dll plugin installed, no Unicast Device configure.
DVBServer is running with default settings.
Computer XYZ: Has DVBViewer 4.5 but no DVB Hardware. Here I want to watch TV over the network from ABC which has DVB Hardware to receive TV signal. I added the Unicast Device with all config from the server.
Now?! How do I see the channel list from ABC? I am really lost.
Thanks. Will try this out tonight.
But isnt this possible with DVBViewer only? The installation already contains a DVBServer part, so why would I need the recording service. I try to avoid conflicts when watching TV on this box, i.e. watching TV on DVB-C and DVB-S cards with DVBViewer (in living room), receiving DVB-T channels on DVB-T card on the same machine, but streamed to another room because there is no DVB-T reception but only LAN (basement).
ABC(living room)
- DVB-C: active and "locally" viewed
- DVB-S: active and "locally" viewed
- DVB-T: active but "remotely" viewed/streamed
XYZ (basement)
- no DVB hardware. Only DVBViewer controlling ABC DVB-T part via LAN
Thanks.
The recordingservice is the new Server, its made for this you want du with your ABC and XYZ. Read the guide like @Tjod wrote and try it.
PeterF
Thx! Works very nice with RecordingService and DVBServer. I am now putting all the DVB hardware in one box and stream to 3
TV's. Great stuff!
