Could DVBViewer Pro record 2-3 channels at the same time?
Mr. Man-wai Chang
Is there a guide on this?
yes. No need for a Guide. Just set a Timer for more than one show at the same time. If possible DVBViewer will record the shows. One Tuner can record all unencrypted Channels from one Transponder. 2 Tuners all channels from 2 transponders and so on. Nothing to configure here.
You meant DVBViewer would auto-magically select another tuner when one tuner was being used to record a show? And that I do not need to select a tuner in the schedule?
... if casually the channels belong to same transponder, you can recording with a one tunner card
test it !!
