Which tuner am I using?
Cian
I have just added a second tuner card, but I can't see which tuner is working at any given time. I there some display screen that tells me which tuner I am using?!
Thanks,
C.
Hello Cian,
Move the cursor into the second field from the left
in the lower DVBV-bar (XX %).
Then you will see it.
Sorry for my bad english.
Or Recordings Statistics > Device Status
The TV card in Bold is used for the main pictur, the TV card in italic is used for PiP.
And recordings are listed below the device.
