less then zero
toblerone
is it possibile to add negative values in "time after" (and in the "time before" maybe someone need that one) in the recording option? as well in the recording service
usually the epg report the same time for the start&end with two events, can be useful
thx
i see that is already possible to use a negative value in the configuration tab of the recording service webinterface
i did not noticed it and it is enough for me
regards
Edited by toblerone
