schnix Posted November 5, 2010 Posted November 5, 2010 hi i use recording service 1.6.5.2... My LG 42le5500 is showing me the DVBViewer Mediaserver, i can select TV, Radio, Recordings, ... I successfully viewed recordings, but when i select TV and try to watch "Das Erste (deu)" for example, my LG turns off and on again... No channel works for me I don't know where the problem is, tv or software... Does anyone know that kind of behavior, maybe someone is successfully using lg tv with dlna? thanks for help schnix support.zip
schnix Posted November 11, 2010 Author Posted November 11, 2010 is something wrong with my post or do you need more information? do i need to prepare special testcases for your support file? schnix
schnix Posted November 21, 2010 Author Posted November 21, 2010 hmm i still don't know what to do... is there something wrong with the support file or is everything fine and you dont have any idea why it does not work? a response would be nice schnix
majstang Posted November 21, 2010 Posted November 21, 2010 (edited) I don't think anyone in here has the knowledge answering what you wanna know. I don't know much about DLNA, but I do suspect you are using your network for it. Why dont you use a HDMI cable between your HTPC and TV instead? Then it is only HDCP that can ruin your userexperience. Edited November 21, 2010 by majstang
schnix Posted November 22, 2010 Author Posted November 22, 2010 thx for your answer. one reason why i dont use hdmi is, that my pc monitor has a higher resolution than fullHD, and i dont wanna change it every time... who has the knowledge of answering me? should i ask in the german forum, maybe the developer would catch a glimpse over there? thx schnix
majstang Posted November 22, 2010 Posted November 22, 2010 who has the knowledge of answering me? should i ask in the german forum, maybe the developer would catch a glimpse over there? Well, when checking the wiki for dlna this comes up: http://en.DVBViewer.tv/wiki/Dlna Yes, you may have better luck in the german forum.
