peo Posted November 11, 2010 Posted November 11, 2010 HI . With the new DVBViewer 4.5 the remote imonpad dotn full work. only few button works. arrows (channel +-, volume +-), esc, ch list ,enter and app.exit all ather button no work. if I try to theach the ather button DVBViewer dont see at all the comand just the few button are able to reprogram in DVBViewer 4.2 the remote (with same setting ) work perfect with no problem. (imon file in DVBViewer and DVBViewer file in imon) both version ar installed in the same pc (4.2 and 4.5) any suggest? support.zip Quote
majstang Posted November 11, 2010 Posted November 11, 2010 (edited) For iMON pad to work you must change all DVBViewer keyboardcommands in Options-->Input so they correspond with the keyboardcommands you have set for the pad buttons in the iMON software. Edited November 11, 2010 by majstang Quote
peo Posted November 11, 2010 Author Posted November 11, 2010 (edited) hi. thanks to help but both versione of DVBViewer are installed at same time. (change the file name in CMUV so I can use 4.2 or 4.5) and I have saved the configurate file of the remote. my problem is in the input configure file. wen use the dvbviewr 4.5 just a few button are enabled to be configurate . all ather button are invisible notting happend wen try to teach in DVBViewer input for example numbers 0123456789 (and the number have same config. as keyboard) Edited November 11, 2010 by peo Quote
majstang Posted November 11, 2010 Posted November 11, 2010 hi. thanks to help but both versione of DVBViewer are installed at same time. (change the file name in CMUV so I can use 4.2 or 4.5) and I have saved the configurate file of the remote. my problem is in the input configure file. wen use the dvbviewr 4.5 just a few button are enabled to be configurate . all ather button are invisible notting happend wen try to teach in DVBViewer input for example numbers 0123456789 (and the number have same config. as keyboard) Have you created two separate DVBViewer.exe profiles in imon software then (where you set the path to the exe and setting up all keybordcommands for all buttons)? I suspect you have not and that is why you are having problems with one of the installations. Quote
Tüftler Posted November 11, 2010 Posted November 11, 2010 As far as i know there is no way to configure two of DVBViewer installations in iMonManager, since they have the same name. Attention, renaming of DVBViewer.exe leads to other problems! Quote
peo Posted November 11, 2010 Author Posted November 11, 2010 (edited) hi thanks for help you're right imon was unable to connect on the new DVBViewer :bounce: :bounce: kitos.. Edited November 11, 2010 by peo Quote
