Web Interface & Hibernating PCs
Bigus
Hi
This isn't a DB Viewer issue but maybe someone has had the same issue and found a way to achieve it..
That is, I have my media PC set up with DVBViewer and the recording service installed. I also have the web interface setup so I can access it from anywhere via my mobile phone.
Now, my PC is set up to go into hibernation mode after about 15 minutes. The recording service is fine with this as it will bring the PC out of hibernation when it needs to record something. However, if I am out of the house and think of something I want to record, when I try and connect to the web interface from my mobile phone, I get no response as the PC is hibernating.
Is there a way of bringing the PC out of hibernation when a connection is attempted to the web interface?
Bigus
Ah-ha, thanks for the pointer. i'm on windows mobile but had a search & there is a wake-on-lan client called 'wol everywhere' which looks like it'll do the trick :-)
