No video when DVB Viewer Pro v4.5 is started from XP's Task Schedu
antdude
Hello.
I use an old, updated Windows XP Pro. SP3 with DVBViewer Pro v4.5.0.0. I use XP's Task Scheduler to automatically launch DVBViewer Pro and then to start watching live (useful if I forget ;)) or start recording minutes later. I noticed I get no picture/video on the screen, but with its audio (AC3 Filter) if I lock Windows session (winkey + L hotkeys). I have no problems if I don't lock my Windows session. I also noticed its recordings (.MPG) does work when I play it back when it is done. It is just I don't see anything live in DVBViewer from locked session.
Is there a way to fix this?
Thank you in advance. :)
Edited by antdude
Remove the tick by "Restart DVBViewer Without Tuning Last Channel" in DVB Task Scheduler and make sure that Options > TV + Radio > Tune last channel on start is ticked.
Hi.
Thank you for the quick response/reply!
I do not see "Restart DVBViewer Without Tuning Last Channel" in Windows XP's Task Scheduler. http://img717.imageshack.us/img717/8305/screenshoty.gif for screen captures/shots of the task properties. Am I missing/overlooking something?
DVBViewer Pro's Options' "Tune last channel on start" was already checked.
Try the current version:
Uh, from where? I have all the updates from Windows/Microsoft Update.
:oops: I though you are using the DVB Task Scheduler (Members Section)
Nope, XP's Task Scheduler. :)
