Excel channel sorting
Swe_Sven
Would it be possible for someone to develop some excel interface to help sort channel lists (channel.dat). This would be very grateful and appreciated. I found it easier to work with tables and such to sort order, like channel number.
Regards
Swe-Sven
Export the channel list in the channel list editor as .csv, edit it in Excel and save it as .csv. And then import it in the channel list editor.
Hi Tjod,
If you mean ChannelEdit.exe and save as csv, this does unfortunately not working. It had however been an opportunity for the handy guy. The only ChannelEdit.exe exports is the field name, the rest is empty.
Regards
Swe-Sven
