DVBVIEWER manual transponder searching?
miro111hrzg
Best regards,
I would like to know is it possible to perform a little bit more specific manual scanning of transponders in DVBViewer?
For example, is it possible to set polarization(vertical, horizontal), symbol rate and fec instead of just providing the frequency while trying to search some transponder manually?
Thanks.
Use Transedit :bye: .
hehe, I knew that. That's why I asked this question.
But why not to make that option directly in DVBViewer instead of messing with transedit?
That's how I was doing since I noticed that there are problems when importing channels from old transedit 3.5.0.0. to newest 4.5 DVBViewer.
Import will mix the polarizations, what is vertical , becoms horizontal, and channel list will not work.
That's why I'm looking the way to work only in DVBViewer!
I didn't test newest transedit yet.
Maybe there is option but I don't know how to set it.
