Two SS 2 HD DVB Viewier
rafal82
hello, I have SS 2 HD and I want to buy another SS 2 HD. My question is whether those two cards will work in DVB Viewier no matter, it's about PIP, record one channel and watching another channel
To avoid drivers/device conflict, go for your 2nd. card which uses WDM drivers as opposed to SS2-HD which is BDA based.
how I bought Proftuners DVB-S2 MPEG4 USB 7500 that would be a better solution?
two BDA tuners, even the same ones are no problem. Once you install it you will automatically be able to record and watch or do pip. No further configuration neccessary
