How to check if LNB is connected
jura555
because I have a lot of cabels inside my house, I need to check if I connect correct one into my computer. So I need to know if this right coaxial cable is connected to LNB or not. Is there any function in DVBViewer to check?
Many thanks for answer.
BR Jiri
..by tuning to a channel ;)
Hi, thanks for reply.
So I will tune a channel on DVBViewer and then I can change cables connected to my PC and when I connect correct one, signal immidiatelly appears?
Many thanks.
Beware of attach/detach LNB cables with PC powered on: the receiver plug carry LNB power and there can be a voltage differente to the heart that can damage permanently the receiver input circuitry...
:bye:
