help subtitle autochange
matan
Can someone help me i have a problem with subtitles ,a channel that i wanna watch has serbian(srp)dvb subtitle but DVBViewer has only serbian(scc)to set in options and it cant detect(srp)subs,so every time i must turn on manually subs
is it possible to create a script in channelchange.vbs to automatically change subs to (srp) when is detected,please help me.
In the actions.ini you can find: OSD-Show Subtitlemenu = 8247
IDVBViewer.Sendcommand(8247) should show the OSD-Show Subtitlemenu.
I don't understand where do you put IDVBViewer.Sendcommand(8247)
With this you get subtitle menu but you must manualy select srp subtitle. How to write script to get that subtitle automatic when switch to another channel.
Is there list of commands that DVBViewer supports.
Thx
