Some channels do not show up
BelowSky
Channel groups might get dropped if they have similar names and different character CASE.
The same thing apply to "DU", "Du" and "du".
As seen here, "Du" and "du" groups and all of their channels have been dropped from Web Interface.
DVBViewer Pro v4.5
Rec Service v1.6.5.2
Edited by BelowSky
You can manually uniform the similar groups names in one in that way:
- select the group in the Channel Editor
- use the same name for all the similar group
- click apply
- save the Channel List
- close DVBViewer
- reopen DVBViewer
then you have all the channels in a unique group...
:bye:
Thanks Gioxy :) , that worked for me.
Though that doesn't change the fact that this is a bug.
You're welcome...
...this is a bug.
...but perhaps this could be a nice feature for others (BTW not for me...)
Someone else wants to share his opinion on this?
:bye:
The bug is not the small or capital case naming in DVBViewer, I mean I know thats a feature.
The buggy one is the Recording Service which takes one group and ignore the rest.
Agree (sorry, I haven't got the right point...), so no other user opinion is necessary...
...hope Lars_MQ can solve that soon...
:bye:
Confirm this bug, for me, with this bug, i put all my channels into one group till it get fixed.
Edited by bogdan1980
