UseFav tweak - for numbers too?
uglyned
I'd like to use the usefav tweak so that mini epg browsing uses that channel order.
When it's set though, if I press '1' on the remote control, I go back to the numbered channel one, not the favourite channel one.
Is there another tweak I can use so that when I press '1' on the number pad, I go to favourite 1?
Thanks.
Looks like a wrong remote configuration, you have to assign the buttons to the favourites and not the channels.
