Mygica TD-312: unable to find channel
Mr. Man-wai Chang
The tuner Mygica TD-312 5-in-1 USB adaptor.
http://www.everbesthk.com/1-home/highlight/0257-9AUG2010/my-td312.htm
(I was unable to find a English webpage about it in the distributor's website so far...)
DVBViewer Pro 4.5 listed 2 hardware devices: "Realtek DTV Filter" and "Realtek DTV Filter (2)"
The country is Hong Kong.
Channel Scan (Terrestial) using both devices failed to find any Hong Kong channel.
Both TotalMedia and MultiViewer, however, found all Hong Kong channels.
I suspected that DVBViewer used DVB-T mode rather than DMB-TH mode when doing the scan.
What should I do to fix it?
Edited by Mr. Man-wai Chang
Attached is the support.zip from the PC with Mygica TD-312 and Mygica D689
  • 2 months later...
  • 4 weeks later...
Yes, you are right.
Download http://www.magic-pro.com/download/Magic-TV/Switch%20Tool.zip, and switch
It works! Thanks.
However, my TD-312 needed to be replaced first before the switch mode tool worked with it.
I had tried that tool once I saw it, but the original TD-312 was not detected by the tool.
