HdHomeRun and DVBViewer
vizz
Hi.
I don't seem to find the HDHomeRun tuner under supported devices, do you plan to support it fully ?
It works somehow with the whole transponder, but selection of the single program which is more network light doesnt seem to work at this time.
Thanks in advance.
Peter
  • 1 month later...
Hi.
Thanks in advance.
Peter
Interesting. I thought it would be fully supported by now. I'd like to buy the dual tuner device (ATSC).
Yes, I thought that aswell - but it doesn't yet.
Strange though, when you see that Silicondust is releasing a new network attached tuner with 3 internal tuners now. (HDHomeRun Prime) http://www.silicondust.com/products/hdhomerun/prime/ .
I wrote eailer that it works with the full transponder, and it does - but not 100% stable.
Sometimes DVBViewer doesnt release the HdHomeRun tuners after use and during channel change - so suddenly you end up with "No Available hardware".
It would be great if DVBViewer could reply on this thread if they will support the device in the future or not.
Read this aswell regarding DVBViewer and HDHomeRun: http://www.silicondust.com/forum/viewtopic.php?t=9578
/Peter
Edited by vizz
/Peter
Bummer. I did notice support is a bit weak. They're awesome when they're communicating since I had to help them with ATSC issues in the past. I guess we will have to use another software to replace it for this tuner device. Grr. Wake up DVBViewer staff! ;)
No special handling, it's the same procedure for all devices, and it works with all devices except... so who is to blame?
Nevertheless I would play a bit with the hardware options, particularly "Stop stream while tuning", "Direct tuning" and "Use internal Network provider filter". Maybe one of the combinations is more suitable for the device/driver. We can't test ist, none of the developers and testers owns a Silicondust device.
Hi.
Regarding the possibility to test on a silicondust device, I understand that SiliconDust is interested in lending out devices to developers (You) - please read the following post http://www.silicondust.com/forum/viewtopic.php?t=9578.
Perhaps you can try to contact them again and refer to the above thread ?
/Peter
