safer Posted December 6, 2010 Posted December 6, 2010 Hi, LNB power on my skystar2 card PC truned out to Off? it works only when connecting to LNB out(loop) in ordinary receiver but it does not work when conecting directly to LNB? I formatted my pc and I used different slots ,different drivers,different windows versions,and different dvb softwares including DVBViewer.my question is how can I make LNB power of this card be back to ON? I am waiting 1 Quote
safer Posted December 7, 2010 Author Posted December 7, 2010 Thank you for you reply,but as I said,it is working if it connects to LNB out in the ordinary receiver, in fact I read on some forums that LNB power my change to off when conceting to LNB out, if so, I repeat my question how does it restore to ON? how can I do that? I am waiting a solution from you. Quote
Derrick Posted December 7, 2010 Posted December 7, 2010 I am waiting a solution from you. ..buy a new one if it's broken it is working if it connects to LNB out in the ordinary receiver When connected in loop through mode, the receiver feeds the lnb. Or can you switch your card independently from a high band channel to a low band channel without channel switching in the receiver?? Quote
safer Posted December 7, 2010 Author Posted December 7, 2010 thank you for your suggestion of buying a new card,I wil do that but because it works I need some time to find a solution to solve the puzzle of making LNB power ON/OFF. my card now works whenever the receiver is ON on the same frequency but if the receiver is off,it does not. I ask have one heard that LNB power on skystar2 may turn out to OFF? I read on properties of this card that LNB power can be disabled? if so how can make it disabled or enabled? if we know how lnb power is disabled we can enable it again. Quote
Derrick Posted December 7, 2010 Posted December 7, 2010 if we know how lnb power is disabled we can enable it again. atru! ..get yourself some spare parts and a soldering iron Quote
