It is impossible to read the DVBViewer help manual
Gippi
I have downloaded several times the DVBViewer 4.5 HELP FILE , called DVBViewer.CHM. But, when I open the manual, the index only is readable, all other pages are blank and on each of them there is the message:
Navigation to webpage was canceled.
Why this happens?
Thanks.
Gippi
Most likely due to some security setting in your PC. CHM help files are displayed by the Internet Explorer resp. by IE components. Search the error message with Google...
Thank you very much, Gray, for your suggestion that allowed me to find the solution.
The DVBViewer.chm file was locked.
Solution:
Right-click on the CHM file, and select Properties from the popup menu. Click on the Unblock button immediately below the Advanced button on the General page. Click Apply to show the content. Once the CHM file has been unblocked, the Unblock button disappears
Gippi
